Farmall Tractors Discussion Board
Farmall H rises and lowers in rpms, Carb or Gov?
Posted by Frustrated on July 02, 1999 at 19:22:16 from (156.46.215.47):
My Farmall H rises a lowers in rpms, could the governor be causing this or could the carb be causing this? I know the governor controls the carb but if the carb malfuntions the governor will react. It occurs mostly in the mid range of running? Do I need to change some adjustment? I just took the carb all apart and soaked it in cleaner, things appear to be clean did I miss something? Could the governer weights be out of wack? Their are no broken parts in the governor. This sounds really bad and it is hard to drive this way.
Post a Followup
: Re: Farmall H rises and lowers in rpms, Carb or Gov?
