Farmall Tractors Discussion Board
Re: Oil Pressure Super C
Posted by The Red on July 04, 1999 at 12:14:32 from (216.192.171.59):
In Reply to: Oil Pressure Super C posted by Curt on July 04, 1999 at 11:08:02:
When its cold, where is the needle pointing at? If it is just between the letter o and I then I would plan on dropping the oil pan and make sure the inlet screen is clean. If it is, then I got a feeling the 2 gears in the oil pump are worn. I went through this problem on my 51H. Cleaning the screen made a big difference but I finally swapped oil pumps and it made a big difference. When that guage is near the red you will not have enough proper lubrication.
Post a Followup
: Re: Re: Oil Pressure Super C
