Farmall Tractors Discussion Board
Wiring for generator on m THE RED
Posted by Rick on July 05, 1999 at 06:42:31 from (206.31.186.210):
Help, Need to know how to wire the generator and reg for a M. Has a 12 volt gen, 8volt battery. Have new reg and gen check over. Can't get it to charge. Problem is, took gen off tractor, lost my map to put it together.Need help on wiring.
Post a Followup
: Re: Wiring for generator on m THE RED
