Farmall Tractors Discussion Board |
Re: Wiring for generator on m THE RED
Posted by ltf in nc on July 05, 1999 at 11:36:51 from (206.228.213.185):
In Reply to: Wiring for generator on m THE RED posted by Rick on July 05, 1999 at 06:42:31:
Rick, if you will provide as much detailed info as you can gather from your tractor wiring problem I will try to walk you through. I will need to know wire size, colors, location, number of terminals on device, do you have an amp gauge,what you are using to start the tractor with (key switch/relay) etc. Describe the gen and the reg. It will take several posts but I think we can get the tractor to charge.
Post a Followup
