Farmall Tractors Discussion Board
Re: Oil Pressure Super C
Posted by Kent Morris on July 05, 1999 at 08:24:00 from (205.188.199.183):
In Reply to: Oil Pressure Super C posted by Curt on July 04, 1999 at 11:08:02:
Curt,
The first place I would look is the oil pump. Frequently the oil pump cover is warped and allows the thin gasket to leak or blow out.
1. If the cover is warped, which it probably is, it will need to be refaced to a true surface.
2. The gasket(s) are also used as shims for gear to cover clearance. I don't have my book available now to give the clearance spec.
3. Don,t over tighten the cover bolts.
Good Luck,
Kent
Post a Followup
: Re: Re: Oil Pressure Super C
