Re: Somma u guys come up with the dangest worrys
Posted by mkirsch on March 24, 2009 at 05:21:02 from (64.80.108.55):
In Reply to: Somma u guys come up with the dangest worrys posted by Farmallb on March 23, 2009 at 20:27:06:
Yeah, and that 1 that tipped probably would've gone over even with a wide front, because wide fronts do not help with stability AT ALL. They pivot in the center. By the time the front end hits the stop where it could stabilize the machine, you're already past the point of no return, and you're going over.
It's a myth. It's an old wives' tale. Wide fronts are not more stable. They ride better because in most cases, only one wheel hits the pothole instead of both wheels. They make it easier to see where the wheels are pointed.
You also have to remember that a lot of the people running these machines now are not old hands that grew up on them in the 40's and '50s. It's the next generation who grew up on more modern tractors that take a lot less skill to operate. After about 1963 you didn't need to know how to set up a tractor and plow because the tractor was so heavy and powerful you could just point and go.
