Farmall Tractors Discussion Board
Re: Re: Re: tractor support?
Posted by Brent Brueland on July 08, 1999 at 06:35:31 from (205.246.168.30):
In Reply to: Re: Re: tractor support? posted by RAW on July 07, 1999 at 19:12:54:
DO NOT USE BUILDING BLOCKS OR THE FAST HITCH! I have personally seen building blocks crumble even though they look perfectly new, and I wouldn't want to take a chance on a hydraulic hose or other leak developing and having the hitch let the tractor down. Solid concrete blocks will be your best (economically) bet, and you can use them for many, many other things when you're done. They make a good base for building trailer frames, blocking up heavy trailer tongues, etc...
Post a Followup
: Re: Re: Re: Re: tractor support?
