Farmall Tractors Discussion Board
Re: 1468 Motor
Posted by Kenneth Updike on July 13, 1999 at 05:34:38 from (205.173.178.18):
In Reply to: 1468 Motor posted by redfan on July 13, 1999 at 04:47:13:
I beleive the DV-550 was made in either Indianapolis, or maybe chicago???? The engine its self is a good one. DO NOT EVER TURBOCHARGE a DV550, and they will last a long time. Sure its a sleeveless block and yes the main bearing caps are of poor design. However, IH built the V-8s to compete with the 1155 V-8 massey. That tractor didn't go far either. If a competitor was going to have a V-8 tractor, then IH D#@m well better have one too.
The 1468 & 1568 are vintage tractors. Not many of them left are still farming. Overall they are a nice machine, especially if they still idle on 4 cylinders.
Post a Followup
: Re: Re: 1468 Motor
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
