Farmall Tractors Discussion Board
Re: Re: Super A Compression
Posted by Tim B on July 17, 1999 at 16:26:52 from (208.192.18.178):
In Reply to: Re: Super A Compression posted by The Red on July 17, 1999 at 14:05:42:
I'm burning a lot of oil, I was afraid it was bad rings, now the culprit seems to be the head. My #2 plug was nearly oil fouled. Hopefully its just guides and seals maybe the head gasket. I've heard that SA have a history of cracked heads is this true? If so is allways in the same place?
Post a Followup
: Re: Re: Re: Super A Compression
