Farmall Tractors Discussion Board
Re: Re: Re: Super A Compression
Posted by Phil Auten on July 19, 1999 at 06:07:35 from (206.175.72.226):
In Reply to: Re: Re: Super A Compression posted by Tim B on July 17, 1999 at 16:26:52:
Tim,
Generally the A-B-C and Supers of these models don't have serious head problems UNLESS they are overheated. Then they tend to crack across the combustion chamber of the center cylinders. Had a '49 C with that problem. Found a rebuildable head for $100, spent another $165 to have it rebuilt, problem solved. If your head is cracked, you'll find water in the cylinder(s) where the crack is.
Good luck,
Phil
Good luck
Post a Followup
: Re: Re: Re: Re: Super A Compression
