Farmall Tractors Discussion Board
Re: Re: Stuck W-6
Posted by Louis G. on July 17, 1999 at 23:11:49 from (207.19.4.144):
In Reply to: Re: Stuck W-6 posted by ltf in nc on July 13, 1999 at 17:55:35:
You can eliminate most of your problems if you will get some Justice Brothers JB-80 penetranting oil. It is not necessary to use excessive amounts either.... you just need to get the parts wet. Do you buy cheap worthless wrenches that bend and break when you apply a little pressure? Or do you buy wrenches that will withstand the pressure and save your nuckles? Get a penetrant that will work..... JUSTICE BROTHERS JB-80. IT WORKS!!!!!!!
Post a Followup
: Re: Re: Re: Stuck W-6
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
