Farmall Tractors Discussion Board
Re: Stuck W-6
Posted by ltf in nc on July 13, 1999 at 17:55:35 from (206.228.213.28):
In Reply to: Stuck W-6 posted by Jon on July 13, 1999 at 14:31:21:
I am going to share something that can fix your problem but I want to start by cautioning you that you could damage your engine. Done carefully and patiently, the end results should yield what you want, an unstuck engine. I am going to suggest two methods. Both are similar but the first is unlikey to damage anything. Get a spark plug that fits your engine and break the porcelin out of it. Braze to the plug base a male coupling like that used with the disconnect in your air compressor line. Locate which cylinder is on the compression stroke and mount the device to that cyl. Have all other sparkplugs out and block the clutch pedal down and place the trans. in neutal, put plenty of penetrating oil in each cyl. Hook the air hose from the compressor to the device and start the compressor. Run the air pressure up to approx. 110 PSI. If the engine does not turn do not go any higher with the pressure. Let the system set for a day or so under this pressured situation. If it is still stuck devise a means to circulate hot water through the engine and heat the water to near boiling. It should now be unstuck. If it is still stuck repost and we will go into the second method
Post a Followup
: Re: Re: Stuck W-6
