Farmall Tractors Discussion Board
Re: Farmall H gas problem
Posted by TomH on July 18, 1999 at 05:25:48 from (206.99.145.205):
In Reply to: Farmall H gas problem posted by Ryan on July 17, 1999 at 16:23:07:
The carb has a drain plug on the bottom. What happens when you unscrew it and let the gas pour out? Is it a good healty stream or a trickle? That's an easy way to check for fuel line/float problems.
And here's a kind of "no offense intended" question: are you sure the fuel shutoff valve under the gas tank is all the way open?
Post a Followup
: Re: Re: Farmall H gas problem
