Farmall Tractors Discussion Board
Farmall H gas problem
Posted by Ryan on July 17, 1999 at 16:23:07 from (205.188.196.39):
We recently restored my 1952 Farmall H and we had to take the gas tank off. When it was all put back together and started we noticed it was flooding. My grandfather cleaned the carb and said we could have stirred up dirt down in the tank. We took it to a show and when I was driving around the track it was sputtering like before. Once it sat a couple of minutes you could start it and drive for a liitle bit then it would do it again. So we put a in line filter on the line and cleaned the carb again. When I was driving around the house to make sure it was working right it seemed to run really good. Once it ran for about a half an hour it acted like dirt was in it. I waited a minute and it started on the first time. Then a little later it did it a couple more times. When you let it sit for a couple of minutes it starts right up. I think that the filter we put in the line is not letting enough gas get through and when you let it sit a minute enough gas seeps through to let it run for a little while. Can someone help PLEASE!!!!
THANKS,
Ryan
Post a Followup
: Re: Farmall H gas problem
