Farmall Tractors Discussion Board
Re: cub not charging
Posted by ltf in nc on July 19, 1999 at 13:03:17 from (206.228.213.21):
In Reply to: cub not charging posted by rick retter on July 19, 1999 at 11:27:19:
Strip the ends from a piece of insulated wire and connect one end to the field terminal at either the generator or regulator. Start the tractor and at a fast idle short the other end of the wire to a good ground. If the charge rate goes up, service the regulator. If the charge rate does not change, service the generator. This test assumes the battery is + grounded and the wiring is intact. If the battery ground is wrong, repost.
Post a Followup
: Re: Re: cub not charging
