Farmall Tractors Discussion Board
Re: alternator/generator
Posted by ltf in nc on July 24, 1999 at 10:13:32 from (206.228.213.224):
In Reply to: alternator/generator posted by Dexter on July 24, 1999 at 08:10:45:
I read your post closely and I was unable to determine what you did for the regulator. Definitely you need to add a 1.4 to 1.6 ohm ballast resistor. This can be purchased at any auto supply store for a few bucks. Place the resistor in series with the wire from the switch to the coil. The resistor should correct the point problem but you still have a charging fault.
Post a Followup
: Re: Re: alternator/generator
