Re: What's better for plowing Wide/Narrow?
Posted by LenNH on March 25, 2009 at 12:57:56 from (71.235.191.159):
In Reply to: What's better for plowing Wide/Narrow? posted by Farmall Bob on March 23, 2009 at 04:55:09:
A good draft line for the plow can make some difference to the steering. The F-20 and Regular I used to use were so wide that the plow was always hooked way over on the right. You had to fight that right-hand pull all the time. If you can hook near the middle and adjust the trailer plow right, there shouldn't be much of a pull to the side. Never used a wide-front F-20, H or M, so can't say anything about advantages for that configuration.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
