Re: Cub steering gear is loose.
Posted by George Willer on January 26, 2002 at 18:43:52 from (64.254.131.40):
In Reply to: Cub steering gear is loose. posted by Jack Gibson on January 26, 2002 at 16:08:25:
Jack,
I have repaired several that were loose in that spline area. I wouldn't recommend welding, due to the possibility (probability) of warpage. One was so loose that there was no way to be sure the worm wheel would be centered. I carefully machined reference surface on each part and made a thin bushing to fit between to locate them concentrically. Then with both parts well cleaned, I permanently bonded them together with J B Weld.
Another that was loose, but wasn't as bad, I bonded directly. Try it...I'm sure you will be pleased with the results. J B Weld was made just for this purpose.
Oh...take care adjusting the vertical play out of the worm shaft too using the nut on the bottom before clamping the arm.
Send us a report when you have it finished...it will give others hope.
George Willer
Post A Followup
: Re: Re: Cub steering gear is loose.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
