Farmall Tractors Discussion Board
Re: Light switch wiring
Posted by The Red on July 27, 1999 at 13:51:43 from (206.246.187.2):
In Reply to: Light switch wiring posted by Joe Berendzen on July 27, 1999 at 13:41:11:
The hi low charge you refer to was on the older Hs and Ms when the cutoff voltage regulator was mounted on the generator. I am guessing your regulator is closer to the steering post. I had the later type light switch on the 51H, before going with the older settup, and it is simply off, dim and bright.
Post a Followup
: Re: Re: Light switch wiring
