Re: H Transmission cover removal
Posted by Roger on January 27, 2002 at 20:13:29 from (209.224.32.214):
In Reply to: H Transmission cover removal posted by BTD on January 27, 2002 at 14:45:17:
I had a real hard time getting the transmission cover off my Farmall MD. Several bolts twisted off just below the surface of the cover. I tried jacking and prying, but nothing worked. These broken bolts were so rusted in that they wouldn't allow the cover to come up. Finally I drilled out the broken bolts down to about a half inch above the main case just so there was enough bolt to unscrew with a vice-grip after I finally got the cover off. Once I had the bolts drilled out the cover came right off. Roger
Post A Followup
: Re: Re: H Transmission cover removal
