Re: Re: Farmall Painting 101
Posted by Dave_Id on January 28, 2002 at 13:25:54 from (63.15.161.161):
In Reply to: Re: Farmall Painting 101 posted by Cliff Neubauer on January 28, 2002 at 10:35:04:
I concur with Cliff on most of what he said about the PPG Omni line. I used the sanding surfacer on the M. It took 10 hours to sand it out, and I just did the sheetmetal. I used 220 for this operation, then reprimed before doing the base coat. For a sealer, use Epoxy Primer and mix up to 10% reducer in your mix. It goes on much nicer with the reducer anyway.
What I do different, is I use 2 stage system instead of the single stage. I have done both and like the two stage better because it's easier to touch up any light areas of red. You don't have to give the whole tractor a wet coat just to touch up one area. Apply three coats of clear over the base coat, any sags can be worked out carefully with a razor blade, and color sand with 1000 grit paper, and buff out with "Klean Kut" and the wool pad, then go to a velcro sponge pad and finish with "Perfect-it", your finish will look like glass, and not a flaw in it.
I didn't use the sanding surfacer on my Massey Harris I restored, and it still turned out very nicely.
I went over to the Community College for a night course in "Auto Painting Techniques" I learned enough to do the job, but also learned how extensive auto painting trade really is.
You can email also if you have any questions. As Cliff mentioned, the PPG # for the red is 71310
Post A Followup
: Re: Re: Re: Farmall Painting 101
