Re: Re: Thanks Ralph and others on Comp on Super C
Posted by Paul on January 29, 2002 at 20:25:07 from (152.163.204.204):
In Reply to: Re: Thanks Ralph and others on Comp on Super C posted by ralph on January 29, 2002 at 17:35:19:
third party image
Hi Ralph, This is the old Super C with my boy Blake Aka "Buck" on it the day we brought it home.I was reading a posting farther down about checking compression and the guy stated it should hold that pressure on the gauge. The old gauge I was useing didn't screw in, it had a rubber stopper on the end and you held it in the hole while turning the motor over. The needle would peak at 100 then quickly loose preasure mostly due to me not being able to hold the gauge that tight against the pressure. If you where me would you get a better gauge or just enjoy the good readings I got today?
Post A Followup
: Re: Re: Re: Thanks Ralph and others on Comp on Super C
