Re: Re: Re: Thanks Ralph and others on Comp on Super C
Posted by ralph on January 30, 2002 at 06:50:35 from (65.45.140.247):
In Reply to: Re: Re: Thanks Ralph and others on Comp on Super C posted by Paul on January 29, 2002 at 20:25:07:
Paul: Enjoy the good readings. For sure you got 100lbs. ..and also important that the cylinders were even. You also said earlier that it starts good; runs good; does not smoke(blue) oil. so relax and enjoy. Sounds like a good stock engine. A compression test is not the absolute best or only test a person can preform but it's quite a good "rule of thumb" to rely on. When it starts blowing lots of blue smoke and fouls plugs..etc etc.. then get serious. R
Post A Followup
: Re: Re: Re: Re: Thanks Ralph and others on Comp on Super C
