Re: Re: Timing marks
Posted by Mike ISW on February 02, 2002 at 05:17:48 from (64.12.102.28):
In Reply to: Re: Timing marks posted by Zonie on February 01, 2002 at 18:43:17:
I don't believe the idler gear has timing marks as you mentioned. It doesn't need to be timed. Line up the single punch marks on the crank and cam. Line up the double punch marks on the cam and magneto drive. As mentioned you may have to look close but they're there. Clean off the fronts of the gears with a good quality brake clean. Good Luck
Post A Followup
: Re: Re: Re: Timing marks
