Re: Farmall M Rear Axle Outer Bearing Metal Seals
Posted by randy hall on February 02, 2002 at 09:37:08 from (63.237.50.109):
In Reply to: Farmall M Rear Axle Outer Bearing Metal Seals posted by lcbateman on February 02, 2002 at 09:01:41:
the outer axle bearings are shielded bearings. the shield helps to hold the grease in the bearing.
Post A Followup
: Re: Re: Farmall M Rear Axle Outer Bearing Metal Seals
