Re: 1586 clutch/tranny problems
Posted by Steven@nd on February 04, 2002 at 18:26:22 from (12.23.184.181):
In Reply to: 1586 clutch/tranny problems posted by Rob on February 04, 2002 at 16:55:57:
Take the floor out, your shifting linkage is going bad. My 1086 got locked in 2 gears a couple years ago. New linkage and it works fine. Sounds like the whine could be from the gears not engaging completely.
All there is are a couple of threaded rods with ball joints on the ends to put into and out of gear, they wear out and you have shifting problems.
HTH
Steven
Post A Followup
: Re: Re: 1586 clutch/tranny problems
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
