12v volt reg for 6v gen.
Posted by Robert C. on February 05, 2002 at 09:17:26 from (208.62.61.194):
Howdy: I'm wondering if a 12v regulator on the MD will fit on a generator for the M. I want the appearance(appearance is the key) of being stock while having the luxury of 12v. Does the vr(voltage regulators) on the M look the same as the MD? Do they have the same poles on the vr? The tractor is primarily for show. I know there were several types of regulators for the M. One on the generator, some were mounted on the rear gas tank support. Thank you for your information.
Post A Followup
: Re: 12v volt reg for 6v gen.
