Re: Old-Dutch others-1586 clutch/tranny problems contined...
Posted by Steven@nd on February 06, 2002 at 18:55:01 from (12.23.184.252):
In Reply to: Old-Dutch others-1586 clutch/tranny problems contined... posted by Rob on February 06, 2002 at 18:32:40:
That is the symptom of TA on its way south. Our 1256 does that, start out ok and then when you get to a hill or pull something it stops. When the TA went out of our 1086 last time it would JUMP when you let the clutch out. And I mean JUMP hard! It was like the clutch wasn't engaging and then all of the sudden it was like popping the clutch out.
Sounds like it's time for a TA.
Steven
Post A Followup
: Re: Re: Old-Dutch others-1586 clutch/tranny problems contined...
