Farmall Tractors Discussion Board
Re: Super C runs like crap when warm
Posted by TomH on July 28, 1999 at 18:19:23 from (206.99.145.201):
In Reply to: Super C runs like crap when warm posted by Goober on July 28, 1999 at 17:17:11:
Not major work. Sounds like the float is stuck, which would explain the leaking gas, and it probably has a too rich mixture which would explain the running poor after it warms up. A carb overhaul kit is inexpensive and simple to do. Other cheap things that probably should be replaced are the rotor and distributor cap. If the spark plug wires look rough they should also be rep;aced. Non-Charging could be generator, voltage regulator, bad battery, or bad wires/connections. Do a little research on how to test a charging system, all you need is an inexpensive multimeter.
Post a Followup
: Re: Re: Super C runs like crap when warm
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
