Re: Re: Governor spring on Super C
Posted by Farmold Phil on February 09, 2002 at 18:36:53 from (216.41.225.156):
In Reply to: Re: Governor spring on Super C posted by boondockjones on February 09, 2002 at 17:17:04:
Thanks. The local IH dealer is about 1 hour drive from here. I was just wondering if a similar size spring from a more local hardware would work? Any info would be appreciated. (Looks like I'll be driving for 2 hours).
Post A Followup
: Re: Re: Re: Governor spring on Super C
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
