Re: Gas dripping from carb
Posted by Bill VanHooser on February 13, 2002 at 18:29:17 from (12.91.164.206):
In Reply to: Gas dripping from carb posted by Dan 130 on February 13, 2002 at 17:56:04:
Sometimes after re-assembling the carburetor, the float can hang up on the gasket. You may have to trim the gasket to eliminate this interference. One way to check whether the bowl is being filled to the correct level is to unscrew the bottom drain plug in the bowl, and with a barbed fitting install a small section of clear plastic tubing. With the open end of this U-tube above the bowl, open the valve and check the level of the gas as it fills the bowl. If too high, it will overflow causing a drip.........Bill
Post A Followup
: Re: Re: Gas dripping from carb
