Re: How big of a generator will a C pull?
Posted by PAA on February 13, 2002 at 18:30:45 from (64.12.103.27):
In Reply to: How big of a generator will a C pull? posted by Matthew on February 12, 2002 at 08:31:53:
Our 140 International will run quite a bit on our 35KW generator. My guess is 10-15KW. It seems it should be fine if you are only running a pump. If you decide to use it on the house or barn, just go easy at first turning things on so you don't overload your tractor. Also, a diesel will keep the RPM's at a more constant speed as compared to the gas engine. As far as a timer to turn off the tractor, I think it would be better for the tractor engine if you run it with the PTO off for a minute or two to let it cool down before shutting it off.
Post A Followup
: Re: Re: How big of a generator will a C pull?
