Re: Farmall M-Smoke-flushing with kero
Posted by Bob Kerr on February 14, 2002 at 09:41:06 from (205.188.197.43):
In Reply to: Farmall M-Smoke-flushing with kero posted by Skip Nelson on February 14, 2002 at 07:58:11:
If the whitish smoke is really smoke and not steam from condensation or a crack in the head or sleeve. It may be burning lots of oil. If it sat for a while and the cylinders got a little rust on them and the rust sometimes will make it smoke some, It might clean up the more it runs, but I wouldn't hold your breath. As for the Kerosene trick, don't do it with just straight kerosene!!!Kerosene is a very light oil, but it is way too light to keep bearings lubed. If you want to flush it out put a 50/50 mix of oil (Diesel rated oil is real good to use for this!) and kerosene in a can and pour it into the spark plug holes and let it sit for a few days. Roll the engine over slowly by hand several times a day if you can and also rock the engine back and forth to let the rings help clean out the ring grooves. Be sure to do it with the spark plugs out. After it sits a few days you can repeat or go ahead and roll the engine over with the starter at a high speed to blow out through the spark plug holes,any kerosene left in there. If you want to clean out the engine block be sure to use 3 quarts of oil to ONE quart of kerosene in a 4 quart system to flush it out and let it run at idle for about a half hour to an hour, Dont drive it around or put a load on it. Diesel oil is good for this too since it has such a high detergent in it., but go back to the regular oil after you are done flushing it. I do have to tell you this though, 80% of engines I have seen that "just need a good flushing out", really in fact "just need a good overhaul", so you might want to save the money you will spend on oil and filters and time fooling around "hoping it works" and spend it on an engine rebuild kit! There is nothing better than a sweet running Farmall that doesn't smoke, and once it is done, you won't have to touch the engine for years, even if you work it daily!
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
