Re: Governor help on IH 140
Posted by Haas on February 14, 2002 at 17:02:33 from (129.37.117.251):
In Reply to: Governor help on IH 140 posted by David on February 14, 2002 at 07:03:53:
Make sure the rod from the governor rockshaft arm to the carburator is completely free and not binding. The pin that holds the yoke to the governor rockshaft arm must slide in and out freely and move completely freely for thinks to work right. If there is the least bit of a bind, it may not go back to idle. Also, get you a service manual and adjust the governor per the manual. If that does not work, you may have a weak or broken governor spring. I'm told the spring is not hard to replace, although I have not done it. You must get a spring through IH. Don't try to use a stock spring from the hardware store.
Post A Followup
: Re: Re: Governor help on IH 140
