Re: Re: M and W9 axles
Posted by Lenn on February 15, 2002 at 04:48:15 from (208.171.56.94):
In Reply to: Re: M and W9 axles posted by Red Rider on February 14, 2002 at 20:55:17:
Thanks Red Rider for the info.
About the loosness of the wheel,when i got the tractor all the splines were tore out of the hub.
I found another wheel and the splines are worn on it also,so one can rock the wheel back and forth a little.The only thing that holds the wheel on is a big washer and 3/4 inch bolt in the end of the axle,it`s a straight axle so there is nothing to tighten up against.What am i missing here,when the wheel is new does it fit that tight on the axle.I supose the axle is worn a bit to.
Thats why i was thinking about changing it back to M axles,am i right that your saying the rear ends are the same,so if i find a retired M i can just change the axles and the seal.
Thanks
Post A Followup
: Re: Re: Re: M and W9 axles
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
