Re: Super M Farmall questions - info needed ??
Posted by Haas on February 16, 2002 at 06:12:35 from (129.37.117.160):
In Reply to: Super M Farmall questions - info needed ?? posted by MJD on February 15, 2002 at 23:54:52:
The axle clamp bolts are different on left and right side because someone likely put new bolts in one side. The bolt size is probably the same, but head size can vary depending on the bolt spec and the manufacturer. Some of the IH bolts have smaller heads than standard SAE bolts. Also, bolts can be regular or heavy hex. The heavy bolts have larger heads and nuts, the heavy bolts are usually used for structural work such as beam connections.
Post A Followup
: Re: Re: Super M Farmall questions - info needed ??
