I504 Radiator
Posted by Steve Pitts on February 16, 2002 at 08:28:42 from (152.163.207.81):
Trying to get the radiator off. Have everything loose but the two bottom bolts that go through the front crossmember. If it's like the Ford I had it's two carriage bolts. The 504 has rubber washers between the radiator and frame and underneath between the frame and nut. Can't see nut well but looks to be a self-locking type which would make sense with the rubber washers. Can barley get the wrench on the nut and I'm sure it will be tight to the last thread. Am considering taking a sawzall and cutting the bolts if I can. Anyone have a suggestion for getting these loose?
Thanks for the help.
Post A Followup
: Re: I504 Radiator
