Re: Farmall A pushing oil into exhaust manifold at idle
Posted by Farmall Freddy on February 16, 2002 at 19:40:44 from (64.12.107.52):
In Reply to: Farmall A pushing oil into exhaust manifold at idle posted by Otis on February 16, 2002 at 17:16:31:
RE: Replacing the clutch. You will have to pull the front end when you do a complete overhaul. By the time you get to this point you are already over half way there to replacing the clutch. I would sure go ahead and pull the block and at least check out the clutch disc, pressure plate and the through out bearing, since you are almost there anyway.
Post A Followup
: Re: Re: Farmall A pushing oil into exhaust manifold at idle
