Re: H or Combine motor?
Posted by Steven@nd on February 18, 2002 at 06:28:02 from (64.68.165.48):
In Reply to: H or Combine motor? posted by Brad on February 17, 2002 at 19:08:42:
Check the casting numbers on both blocks and see if they are the same. Or if they are at least close. Also, you could measure the bolt holes on the rear of the block and the sides to see if they are the same on both engines.
A word of caution: after 25 years without being more than just turned over that engines rings will probably be stuck. Expect oil consumption for a while until the rings unstick.
Steven
Post A Followup
: Re: Re: H or Combine motor?
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
