Re: Generator Problems--Need Help!
Posted by Don Young on February 23, 2002 at 21:50:38 from (66.182.131.18):
In Reply to: Generator Problems--Need Help! posted by Village Blacksmith on February 23, 2002 at 19:49:09:
It sounds like you have a generator that uses an external field ground. To motor the generator correctly, connect a jumper from the F terminal to the frame and connect your battery to the A terminal and the frame. If you do this with the same polarity as the tractor battery, the generator will be correctly polarized. With the generator connected and running, grounding the F terminal will bypass the regulator and give full output. Be sure you have the right regulator!!
Post A Followup
: Re: Re: Generator Problems--Need Help!
