Re: 574 IH HYRAULIC FILL LOCATION
Posted by Diesel Bob on February 24, 2002 at 11:14:29 from (213.1.139.136):
In Reply to: 574 IH HYRAULIC FILL LOCATION posted by MARK on February 24, 2002 at 09:55:54:
Mark it is not a good idea to return the oil back into the tractor through the filler plug as this is well above the fluid level and can lead to airation of the oil and cavitation of the hyd pump which could prove to be expensive there should be a plug under the right hand rear axle housing which is straight back into the transmission below the oil level and is designed for this reason i used to pdi these tractors when new and used to drain the oil remove the plug drill out the centre and braze a hyd fitting into the centre and run a 1/2 inch or3/4 hose up to the back of the hyd housing for the farmer to use as a proper IH recognised return pipe.I live in England and have a 574 HYDRO tractor and know what you mean about the lever if you need anymore help you have my e-mail address
Post A Followup
: Re: Re: 574 IH HYRAULIC FILL LOCATION
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
