Farmall Tractors Discussion Board
Re: Re: 1957 IHC 350D Hydraulics (Change to lift only?)
Posted by RAW on July 30, 1999 at 18:24:39 from (206.153.211.150):
In Reply to: Re: 1957 IHC 350D Hydraulics (Change to lift only?) posted by mdm on July 30, 1999 at 12:41:50:
The 350 is a little different than the 300/400 series. If I remember right there is a pin in the linkage on the bottom of the lift cylinder whick can be moved to allow the cylinder to float. This is where you run it to plow, I do know. I beleive there are also some pins in the lift links that you can pull and get a little float.
Post a Followup
: Re: Re: Re: 1957 IHC 350D Hydraulics (Change to lift only?)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
