Re: 706 hydraulic problem
Posted by RPM on February 25, 2002 at 14:21:37 from (63.110.182.225):
In Reply to: 706 hydraulic problem posted by J.D. on February 25, 2002 at 09:38:39:
First to explain the system, this tractor has 2 separate systems with a common reservoir, the mcv pump feeds the power steering, T/A, and brakes, this is the one that must have problem, back pump in the rear frame ( its mounted low straight down under the clutch pedal on a plate with a lot of bolts <14>) supplies the hyd draft hitch & rear outlets, its working as you describe, the mcv pump & valves are on the LH side on the clutch or center housing ahead of clutch pedal, its hard to tell what is wrong without hooking up test equip but would say to take it off (many bolts), and take it to a dealer or someone that knows how these work. It could be gear key sheared on pump, failed orings & gaskets in mcv, really hard to predict.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
