Re: Farmall A serial #s
Posted by Steven@nd on February 25, 2002 at 17:43:37 from (12.23.184.220):
In Reply to: Farmall A serial #s posted by Sam Haag on February 25, 2002 at 17:19:06:
There is a serial number stamped on the engine block below #1 spark plug. That should be the same as the tractor serial number.
Casting codes can also tell the year they will be something like 4 30 J for April 30, 1940
I=39
J=40
K=41
L-42
Steven
Post A Followup
: Re: Re: Farmall A serial #s
