Liftall yellow spots
Posted by Larry F on February 27, 2002 at 20:40:24 from (216.202.132.34):
Finishing total restoration on '50 H..Took Liftall out for rebuild and it has two yellow painted spots on pump. Does anybody know if this is the same as the 'yellow 8' on the higher pressure Liftalls?? I'm also interested in knowing when IH made the switch from the low pressure Liftalls to the higher pressure units. Finally, (sorry this is long) I've been using Hy-Tran in Liftall and I'm curious how much increased pump pressure (if any) might result from using 30 wt non-detergent oil as originally called for in owners manual. Thanks
Post A Followup
: Re: Liftall yellow spots
