Farmall Tractors Discussion Board
Re: Re: Tightening Rims On Axel??
Posted by Redfan on August 01, 1999 at 05:21:16 from (203.87.53.58):
In Reply to: Re: Tightening Rims On Axel?? posted by Kev in iowa on July 31, 1999 at 20:01:13:
Good point Kev. A common identification for all the different parts would make things a lot easier.But just to throw a cat amongst the pidgeons,nearly all the Inters imported into Australia were equipped with Cast Iron two-piece wheels which had the two pieces bolted together after the tyre and tube had been mounted. As such the RIM was in two pieces,one half cast as part of the wheel centre and the oher half as a large ring which bolted to the first. Have seen this setup on most Farmalls and all conventionals. And they were all painted Red, 100%, no white or silver anywhere. I presume all wheel equipment was sourced locally and fitted after the tractor arrived.Regards, Redfan.
Post a Followup
: Re: Re: Re: Tightening Rims On Axel??
