Re: Cub magneto rinky-dink 90deg. off?
Posted by George Willer on March 05, 2002 at 09:10:04 from (64.254.131.70):
In Reply to: Cub magneto rinky-dink 90deg. off? posted by Paul B on March 05, 2002 at 07:49:57:
Paul, Someone has been fixing what is not the problem. 1. Before the timing gear cover was put on, the gears had to be installed correctly, with the index marks matched up. I hope they were! 2. Assuming the gears are correct, the GOVERNOR has to be installed with the marks matched up also. This is so the drive slot for the mag is at the proper angle. 3. Place the engine at top dead center of the compression stroke for #1. Remove the mag. Looking through the hole, and hiding behind the seal on the side toward the engine, you should see the marks on both gears (you may have to do a bit of cleanup with a Q-tip and solvent) My money says that is where the problem is. 4. If you find the mark on the idler gear, but not on the governor, you will have to remove and install the governor correctly. 5. Now install the mag according to the manual, and you are good to go. George Willer
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
