Re: 350U clutch plate ID help
Posted by Salvage Man on March 06, 2002 at 08:01:59 from (198.247.178.199):
In Reply to: 350U clutch plate ID help posted by George on March 05, 2002 at 17:23:48:
I grind a lot of flywheels off of tractors that have had a button clutch and a woven disc. The only difference between the two types of clutch's is the flywheel that had a woven disc looks better when you take the clutch off. When you grind the flywheels the amount that is removed is about the same. Also a button clutch lasts longer than a woven clutch. If I can get a button clutch for an IH tractor I will put it in. And I also recommend that everyone else do the same.
Post A Followup
: Re: Re: 350U clutch plate ID help
