Re: determining tire sizes
Posted by Haas on March 10, 2002 at 15:17:47 from (129.37.117.6):
In Reply to: determining tire sizes posted by George on March 10, 2002 at 12:49:27:
The 13.5 is the tire width at the widest point. That is only for a certain rim width however, which is consider the normal rim. I think for a 13.6 tire, that is a 12 inch wide rim. The 38 is the diameter of the rim, same as on a car tire. Also, I believe when you say 225 is the width of the tread, that is not correct. 225 is th width on the tire at the widest point of the sidewall, same as the tractor tire. And again, it's the width on what is considered the normal width rim for that tire.
Post A Followup
: Re: Re: determining tire sizes
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
