Re: How do you time a 460?
Posted by ben camp on March 11, 2002 at 18:32:56 from (63.161.124.39):
In Reply to: How do you time a 460? posted by Cliff Neubauer on March 11, 2002 at 18:20:53:
will your 460 backfire or anything? I usuaaly put
1 piston on tdc,set the rotor on the closest wire in the cap and go in firing order on around, then if its off it can only be 180 degrees
Post A Followup
: Re: Re: How do you time a 460?
